car wont move
Old Sep 18, 2009 | 02:17 AM
zflewbyu's Avatar
Default car wont move
I have a 1999 camaro z28 it has a 3000 stall in it and the tranny was built by a local shop around my area. well yesterday i was driving it and when i hammer on it it goes nowhere and spikes to rev limiter and backfires then the car shut off. what will i be looking at to fix this problem? Thanks
Old Sep 18, 2009 | 07:29 AM
FLT's Avatar
FLT
Sounds like you might have a broken pump or another internal issue. Maybe even a rear end. Have someone help you with this when doing this it takes two people. Verify that the drive shaft is not spinning with the car sitting still while in gear. If not make sure that he pump is pumping fluid. You can do this by removing one of your cooler lines at the radiator or external cooler easily. Make sure when you do this that you have a jug ready to catch the fluid if the pump is working properly. Just a FYI the bottom line on the trans is the pressure line. Follow that line up to the radiator/cooler and install it into a jug. Best of luck. Vince B
Old Sep 18, 2009 | 02:29 PM
zflewbyu's Avatar
Well the car still moves if i dont hammer on it, if u just drive it normal it drives fine? but soon as u give it all it has it goes nowhere.
Old Sep 18, 2009 | 03:09 PM
01ssreda4's Avatar
Sounds like a trans or converter issue.
Old Sep 19, 2009 | 12:44 PM
TireSm0ke's Avatar
The backfire is probably unrelated, or maybe you just heard your revs dropping. Sounds like you either slipped the trans pretty bad or your pressures are too low.
Old Sep 19, 2009 | 03:26 PM
zflewbyu's Avatar
If i get a tune to get the pressure turned up will it fix the prob. the car only does it when it has to downshift it's like it wont catch a gear on a downshift. If i roll in first and hammer it it goes?
