transmission slipping help?
i dont know what ur tryin to say? I was driving and I hit the brakes real light then let off, it kinda bounced up about 100 rpms but then right back down to it was at ? Is that what u ment?
I think the Sonnax kit eliminated PWM as well, because from then on, it made a fairly distinct "bump" when the TCC would lock up.
Out of curiosity, do you hear a "grinding" noise when in 3rd or OD and and the converter is locked up? Mine also did this pretty badly after the Sonnax kit was put in. I would be curious to know if anyone else with the auto V6 f-bodies has that grinding noise in the transmission as well.
