6L80e strength & upgrades
Old Sep 29, 2009 | 03:26 PM
Chevy454's Avatar
Default 6L80e strength & upgrades
Throwing an LS7 with a couple goodies into our '10 Camaro, which has the 6L80e, and I'm worried about the stock trans living: what are the limits of this trans, and who can make it live behind the LS7?
Old Sep 29, 2009 | 03:33 PM
bluehawk2's Avatar
I would be interested in knowing the answers as well.
Old Sep 30, 2009 | 11:44 AM
Bo185's Avatar
You could swap to the 6l90 same trans just has a higher input HP rating as well as thicker gears and parts. But its a little longer than the 80. But the stock 6l80 should handle it. You could always swap to the 6l90 later.
The CTS-V with the supercharged LSA 6.2L run the 6l90 BTW.
6l80
Maximum engine power: 469 bhp ( 349 kW )
Maximum engine torque: 439 lb-ft ( 595 Nm )
Gear box torque max 664 lb-ft ( 900 Nm )
6l90
Maximum engine power:555 bhp
Maximum engine torque: 550 lb-ft
Gear box torque max 885 lb-ft ( 1200 Nm )
Old Sep 30, 2009 | 12:23 PM
Z-RATED94's Avatar
How about a FLT level VII?
Old Oct 1, 2009 | 06:16 PM
norris_83's Avatar
i burnt my 4, 5 and 6 on the 6l80e... reason being a 5000lb+ truck revving to 6,500rpm... the lower gears seem almost indestructable.. just the higher ones seem a little weak... learnt my mistake, will be changing gears at around 5500-5800 next time around
Old Oct 3, 2009 | 12:30 AM
tptrans's Avatar
And what does FLT have in the way of a 6L80E
Old Oct 3, 2009 | 01:27 PM
Z-RATED94's Avatar
Their sponsors, take a look at their selection.
