th400 ls1 converter gap to flex plate question
Old Sep 30, 2009 | 11:20 AM
98Camarod's Avatar
Default th400 ls1 converter gap to flex plate question
With the converter fully seated there is about a 1/4" gap between the flex plate and the flat circle mounting plate. The converter will easily move out to the flex plate, but what is the gap supposed to be? I'm thinking some washers are needed.
Hopefully someone can provide some input
Old Sep 30, 2009 | 12:31 PM
Circle-D's Avatar
You want the gap to be about 1/8", so you need to get some 1/8"spacers. SAE washers are .060, that might be the only thing you can find locally. So you could use 2 of those. I have some 1/8" spacers, let me know if you need them. Just make sure they all measure the same thickness.
Chris
Old Sep 30, 2009 | 02:42 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
ditto A+++ for chris
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Sep 30, 2009 | 03:45 PM
98Camarod's Avatar
thanks guys
