86 camaro 4l60e conversion, speedmeter ?
Old Oct 1, 2009 | 12:30 PM
3timeracin's Avatar
Default 86 camaro 4l60e conversion, speedmeter ?
I have a customer with a 1986 iroc we are switching out the 305 for a LS1 and the 700r4 out for a 4l60e from a 1999 camaro. What is offered/needed to convert the speedo over for the 4l60e ?
Old Oct 2, 2009 | 12:52 PM
LS1 BU's Avatar
You could send tail shaft housing out to be drilled for speedo cable and reuse your stock gauges. That's what I'm doing. Or I beleive the aftermarket speedo's like autometer will work with the vss signal.
Old Oct 3, 2009 | 11:07 PM
Dyno paul's Avatar
Default Speedo function
They now make a tranmission extension housing that has both bosses on it one for the Speedometer adapter to connect the cable and a boss to mount the output speed sensor. the gear that goes on the output shaft serves two functions , it has teeth to drive the speedo gear as well as a reluctor for the speed sensor to count teeth then the computer converts it to vehicle speed. i cannot remember the company , possible TCI . if not check Street& Performance web sight.
Old Oct 4, 2009 | 08:01 AM
3timeracin's Avatar
Thanks I found it
