HELP Trans swap info
Old Dec 5, 2003 | 11:05 PM
CrEaMy DrEaM4u's Avatar
Default HELP Trans swap info
I have a 95 Z28 with the 4l60E which im going to swap for a 700r4 will this bolt to the factory crossmember? If not anyone know of any companies that have an aftermarket for the swap..
Thanks
JR
Old Dec 6, 2003 | 01:36 AM
Trans Am Kid's Avatar
4l60e and the 700r4 are the same thing, the 4l60e just being controled by electronics and not a governor. should bolt right up no problems, just be sure and use the tailshaft housing off the 4l60e. Hope this helps
