yank 3200 stall
Old Nov 5, 2009 | 04:42 PM
juanjuan07's Avatar
Default yank 3200 stall
hi, i installed an yank 3200, an set all the things of the pressure, max, minimun, etc. But i havent change the shift points or when the converter should lock. Right know when it changes from 1 to 2 an i am going slow, you hear the converter, like if it was very loose. But when you are going on highway or at wot all goes fine.
What should i do to tight more the converter or to correct that.
Please explain me how to do it since i am really knew working with HPtuners.
thanks
Old Nov 5, 2009 | 11:13 PM
LT1WS6's Avatar
ttt ttt
