4L60E and 600+hp
Old Nov 8, 2009 | 08:01 AM
shawn_c992001's Avatar
Default 4L60E and 600+hp
What would I need to build my tranny to handle ~600+rwhp? Definately a cooler, servo, shift kit, deeper pan, and stall. What else do I need to do?
Old Nov 8, 2009 | 12:20 PM
thunderstruck507's Avatar
don't get your hopes up, I made a thread a couple weeks ago looking for build suggestions for my tranny and no one replied
I can't blame the shops but I was hoping at least a couple others here might have built one of these up instead of buying one
Old Nov 8, 2009 | 12:22 PM
Ok, thanks.
Old Nov 8, 2009 | 02:03 PM
algws6's Avatar
eb02z06 (arun) is putting down over 900 to the wheels through his rpm level 6 4l60 and it seems to be holding up fine.
Old Nov 8, 2009 | 02:13 PM
Did he build it, have it built/buy it?
Old Nov 8, 2009 | 04:30 PM
algws6's Avatar
rpm level 6
Old Nov 8, 2009 | 04:50 PM
PedaltoMetal's Avatar
Not being a jerk but probably because it's been covered numerous times.
Old Nov 8, 2009 | 05:44 PM
02 BLK WS6's Avatar
My car put down 643 rwhp with a 4L60E that I built 3 years ago. It's lived most of it's life in the 500+ rwhp range and never had any issues out of it.
Old Nov 8, 2009 | 06:49 PM
And what parts did you use.
Old Nov 8, 2009 | 08:20 PM
Gatsby's Avatar
I just blew up my 4l60e that JUST got rebuilt with parts supposedly able to handle 450+ rwhp. If you look at my sig you'll see that I am no where close to that number.
I too would like to know what I (or my shop) went wrong.
Old Nov 8, 2009 | 09:39 PM
Punisher_ws7's Avatar
my car made 561/ 555 and went 11.0@125 with 1.55 6o's for a year about 20 passes...
until my # 6 rod bearing decided to cause trouble
RPM level 5 4L60e w/ trans cooler about 2500 miles
Old Nov 9, 2009 | 09:52 AM
Think I'll just buy the "Monster in a Box" and send the shafts out to be cryo treated and call it a day.
Old Nov 9, 2009 | 10:05 AM
performabuilt's Avatar
LS1Tech Sponsor
The big issue is that it takes more than parts, You will not every vendor here has some really storng cars running there units, But you will also note that each ussues different parts to get there, While parts do indeed play a role the fact is the build itself and the little tweaks and mods each builder has learned over the years to make them live.
I have seen over the years many post like this and unfortunatley I have seen more failures than successes in this area. If your going to build your own thats cool look at parts listed for the various vendors and you should get a good idea of wwhat you need in that area, And if this is for a learning experince and not to save money I would say go for it as long as the cars not a daily driver and you have lots of time and pateince on your hands.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 9, 2009 | 05:52 PM
It's a weekend ride and probably only gets driven about 1200mi. a year. I'll have until about April of next year to have it done and I'm the most patient person you'll ever meet.
Old Nov 9, 2009 | 07:05 PM
Slowhawk's Avatar
LS1Tech Sponsor
We have out tranny's done at FLT.Numerous 600+rwhp daily driven 4L60's.Haven't had a problem yet.
Wish I could help you more but we do not touch Auto's for rebuilding.
Old Nov 9, 2009 | 07:22 PM
LS1Tech Sponsor
Ok well good luck and if I can be of any help of course without giving t much away lol just let me know.
Frank
__________________
Call 888-744-6542
Old Nov 9, 2009 | 08:32 PM
Frank
Much appreciated, Thank you!
Old Nov 11, 2009 | 08:53 PM
02 BLK WS6's Avatar
Red Eagle clutches
Kolene steels
Carbon wideband
29 dual element sprag
Transgo HD2
Billet servos
No yoyo high rev pump slide spring
Vig 2800
28k cooler
Stock planetaries
I know there's more that I'm forgetting, but I set the 3/4 clutches up @ .015. I have between 100 and 200 passes and around 15k miles on this build and the pan hasn't been off. I accidently launched in 2nd gear on a 200 shot without killing it (1.60 60').
