TH-400 Question
Old Nov 25, 2009 | 01:07 PM
jh_shady01's Avatar
Default TH-400 Question
How much more power does it take to turn a th-400 than a th-350 or 700r4
Old Nov 25, 2009 | 02:59 PM
cambirdracing's Avatar
About 20-25. Longevity is worth it.
Old Nov 26, 2009 | 11:21 AM
Kevin97ss's Avatar
I thought the only difference was spinning the extra weight of the 400's internals which is 12-15 pounds more than the 350. Should be around 10HP difference....on paper.
Old Nov 26, 2009 | 12:16 PM
jakeshoe's Avatar
I would like to know where the numbers are coming from?
TH400 internals are not 12-15 lbs heavier than a TH350. I've weighed them.
What was the testing procedure to find out how much more power it took?
Since an object in motion tends to stay in motion, etc, etc. If both are at steady speed, there would be little or no difference in power consumption, right?
So power consumption would be mostly determined by the rate of acceleration or deceleration. Acceleration is all we are worried about...
That would mean a 9 second car would see more HP loss than a 12 second car.
I've done the swap back to back, I've weighed the parts, and I build these units everyday, so I always find this an interesting discussion.
Old Nov 26, 2009 | 01:28 PM
Kevin97ss's Avatar
Well, like I said, "I thought" which is tied to my crummy memory.
Extra weight should bring a predictable amount of loss in percent, but if the numbers are off on the weight....
Can you tell us what you KNOW to be true?
Old Nov 26, 2009 | 07:28 PM
jakeshoe's Avatar
I know that swapping from a TH350 to a TH400 in the same car with the same converter in a mid 10 second combo, we saw virtually no change in ET or MPH. .04 second in the 1/4 mile loss.
On other similar combos we have actually seen ET improvement with a TH400, but again slight change in weather or tune could have caused it.
There is 10 lbs difference in the overall weight of a TH350 vs. a TH400, and this is also the difference in rotating weight.
We have gone from a TH400 to a 40+ lb heavier 4L80E and gotten faster. Obviously a different converter but built by the same vendor to match the previous converter.
I KNOW that any HP consumption would be caused by the rate of acceleration and in our experience, into the 10's we haven't seen any difference worth noting or worrying about.
IMO it's mostly mental masturbation to worry about it. If you need the strength of the TH400, you don't need to worry about HP loss.
It's also relatively easy to take out a couple of lbs in a TH400.
Old Nov 27, 2009 | 02:54 AM
jh_shady01's Avatar
I like the abuse i can throw at th th400, I've just heard people say they take more power to turn.
Old Nov 27, 2009 | 11:49 AM
spoonraker's Avatar
If you're not building a dyno queen don't worry about it. It might show a bit of loss on paper, but I know quite a few people who have TH400s and not a single one of them lost any significant amount of MPH or ET, some even gained depending on what they switched from.
Old Nov 27, 2009 | 01:24 PM
Kevin97ss's Avatar
Jakeshoe, thank you for this, very informative.
Do you have any experience with the 2.75/1.57 gear swap for the 400. Is this something worth looking at for a lower power drag car? I've read claims of it increasing efficiency but I don't know what they mean by that.
The steeper ratio in a 400 should make a nice reliable trans for a 450HP bracket car, is what I'm thinking at the moment and may take my build in this direction.
Old Nov 27, 2009 | 05:38 PM
supermouse4's Avatar
From everything I've read, about 45 hp, but the TH400 is pretty much durable for what you want to use it for.
TH350s use about 20-25 hp.
Old Nov 28, 2009 | 09:21 AM
382ssz28's Avatar
These were the estimates from the 70's era:
400-42HP
350-28HP
PG-18HP
700-4L60 series came later, around 45HP.
These are all estimates.
Old Nov 28, 2009 | 11:11 AM
jakeshoe's Avatar
Yes,
I have done the low gear sets in the TH400. They work good in a "underpowered" combo that has decent traction. Lots of Stock Eliminator guys run the low ratio TH350's and the 200's for this reason.
Old Nov 28, 2009 | 11:13 AM
jakeshoe's Avatar
What makes a TH400 use 20-25 more HP than a TH350?
Everybody likes to state this but I've never seen anybody who could post the test information to prove it was true.
Old Nov 29, 2009 | 10:55 AM
In a previous post, I'm using the numbers that were given by GM, their estimates.
Old Nov 29, 2009 | 11:09 AM
jakeshoe's Avatar
Can you reference the information from GM? A link, a publication, etc?
I don't think GM ever put out that information. I know a couple of former Hydramatic engineers and we've discussed this.
I know this is frequently passed along.
IMO it is blindly believed and regurgitated but is just another myth.
Anybody that has had basic science classes in high school should be able realize that there is no way those numbers can be accurate as a "hard" figure if at all.
Old Dec 8, 2009 | 12:33 PM
Jakeshoe, I guess the only way to truly quantify how much power a TH400 or TH350 uses up is to put a car on the dyno and use both transmissions for a test. Assuming that the drivetrain remains the same (rear end and engine), this is the only way to find out the information.
Old Dec 8, 2009 | 04:34 PM
kevin87turbot's Avatar
I've never measured the hp loss through a TH400 or TH350, but a tricked out PG with alum drum and fully rollerized throughout measured 7 hp consumption at 6000 rpm at 300 rpm/sec acceleration. If I get bored sometime, I'll check the TH350 and 400.
Old Dec 8, 2009 | 07:36 PM
jakeshoe's Avatar
A Powerglide is an efficient trans.
They use a Ravigneaux type gearset that is more efficient than the Simpson type used in the TH350 and TH400.
The best way to test them would be on a dyno specifically to measure the power loss.
Under very calibrated conditions.
A car on a chassis dyno leaves too many other variables.
Engine temp, tune and air supply, rear diff fluid temp, tire pressure,etc.
If we are going to test them that way, my dragstrip testing should be as valid, and like I said we have never seen a significant difference either way on any car we've been able to keep the same converter (which unfortunately doesn't happen often).
I've actually seen ET improvement going to a TH400 more times than I've seen loss.
Another factor that many guys aren't taking into account is rear gearing.
Your HP losses in the drivetrain will theoretically go up with steeper gearing.
Old Dec 9, 2009 | 07:32 AM
Circle-D's Avatar
Very interesting stuff Jake. I have had discussions about this as well and from the "tests" I have heard of and seen, I think you are correct. The object in motion theory means that there is no HP loss, only acceleration rate. I have been looking for somebody who knows how to calculate this. I strive to have the lightest possible converter and still be durable, but how much does this help? Would love to know the real answer to this.
Chris
