How do you get the shift linkage rod out of the case?
Old Dec 12, 2009 | 10:20 PM
Hugger's Avatar
Default How do you get the shift linkage rod out of the case?
I have got it loose but it will not pull through the case. I am trying to swap this rod into my other transmission. Help!
The piece I am talking about is the rod that the shift lever connects to. I tried to take a picture but it is not letting me post it for some reason. The rod will slide through the case to a certain point and then just stop.
Old Dec 13, 2009 | 09:29 AM
WE TODD DID's Avatar
What kind of transmission? If it is a 60e, you'll have to remove the pan, remove the "u"-clip that is against the rooster tail, and remove the nut on the back side of the shaft. You may have to take a screw driver and pry the shaft a little bit. Sometimes they are tight getting out.
Old Dec 13, 2009 | 12:17 PM
Hugger's Avatar
Yes it is a 4L60E, I removed all that stuff from above but it is just really tight in the case for some reason. Below is a picture of the linkage I am talking about.
Old Dec 13, 2009 | 01:01 PM
01ws666's Avatar
The trick to the linkage rod is to file it down a little bit right befor the threads start thats the spot that gets stuck. Then pull it out as far as u can, put the nut on the outside and put a wrench under the nut and tap the wrench with a hammer.
