2-3 shift not right
Old Dec 15, 2003 | 03:10 PM
02redSS's Avatar
Default 2-3 shift not right
So i got my auto in this weekend and all seems well.
Its running on a stock 02 auto program and a PT4400
My car has 3.42's so I got a hypertech PP3 to make up for the gear change from the stock auto program.
well this morning it was banging the limiter on the 2-3 shift....so at lunch time i programmed the HPP3 to lower the shift point as low as it would go (i think it was -12 mph) but it is still banging the limiter (now 6600) not sure what the problem is....
any advice?
1-2 seems to work correctly...
Old Dec 15, 2003 | 04:48 PM
Dmoney's Avatar
Same here. Would Autotap tell me what is wrong with it?
Could it be my converter? If I can auto tap it where would I look under?
Old Dec 16, 2003 | 02:10 PM
02redSS's Avatar
tranny went out completely....guess it was just on its way out
Old Dec 16, 2003 | 03:03 PM
Flyer's Avatar
Sounds like it might be the 3/4 clutch pack. Does it try and pull or does it just totally let go? What about part throttle shifts? Do they work, kinda, not at all?
