Removing tail housing on 4L60E
Thanks,
Mike
PS..you will probably want to get a new seal for both locations on the part where the driveshaft connects to the tail housing, and a new rubber seal for the part towards the front of the trans. Coat the rubber seal with oil before and after installation.
pull the driveshaft, you may have to mess with the torque arm mount if its stock, unbolt the tail housing.
