Could this be a tcc solenoid or converter problem?
Old Dec 23, 2009 | 10:52 AM
StreetSilverado's Avatar
Default Could this be a tcc solenoid or converter problem?
I just recently started having this problem to where I can cruise on the highway at about 60-65 (Yes, I usually drive the speedlimit ) and it feels like the converter unlocks. I had a local guy scan it to see what was up, well going down the road it locked up fine then after a mile or so it has this unlock feeling but on EFI live it shows to still be locked could this be a solenoid or maybe the converter clutches are slipping? No codes are being shown.
Old Dec 23, 2009 | 11:52 AM
performabuilt's Avatar
LS1Tech Sponsor
I would try maxing out the missfire tables. Unless the codes disabled if the PCM comands lockup and it does not happen you should get a po1870 code
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 23, 2009 | 02:32 PM
I'd rather not max out the missfire table, it's already been raised. I haven't had this problem with this new set-up since I got it together. I'll have a guy look at it but I doubt the missfire table has anything to do with it.
The codes have not been disabled and I have no P1870 code showing.
If it's a solenoid wouldn't that be showing some kind of code though? I'm starting to think it's the converter clutches slipping.
I'm clueless
Old Dec 23, 2009 | 03:04 PM
Circle-D's Avatar
Can you manually control it with EFI, in scan mode maybe? You could force the clutch on and see what happens.
Chris
Old Dec 23, 2009 | 03:38 PM
slow67's Avatar
Gingervitis Addict
Use a scan tool and see if you can hear the solenoid click on and off (obviously with the car off in a quiet area). If you can hear it click, take it out for a drive. When you think it unlocks, use the scanner to increase the line pressure and see if that helps.
