Speed Sensor affection!
Old Dec 28, 2009 | 01:50 PM
scorpion_z28's Avatar
Lightbulb Speed Sensor affection!
Hi,
i just did an M6 to A4 conversion back to my old 4L60E, i took the car for a test before i take it to the paint shop but i noticed that the car is not shifting through gears! its like I'm moving in 2nd or 3rd gear the whole time i even tried shifting manually but it wont respond.I still didn't install the Speed Sensor, could this be my problem?? i even tuned the car using Tuner cat to change the calibration to match the Auto.
Old Dec 28, 2009 | 07:54 PM
FLT's Avatar
FLT
Without a VSS reading your transmission is not going to function properly. You need to get that sorted out asap. Vince
Old Dec 29, 2009 | 12:05 PM
Thanx where is the best place to get one?
Old Dec 29, 2009 | 01:26 PM
blackhawk0251's Avatar
www.gmpartsdirect.com or your local GM parts dealer should have one. Hope this helps.
