350 turbo
Old Jan 1, 2010 | 09:38 PM
krissoto's Avatar
Default 350 turbo
Getting ready to pull the 4L60 E and replace it with a 350 turbo w/trans brake. I have a 3700-4100 stall and my question is I have a permacool thinline tranny cooler rated 20,000-22,000.... My question is will this be large enough to help keep temps down? Should I just run the lines thru the cooler and completely bypass the radiator due to the fact that it is harder on the pump? And I know that it is a GREAT idea, but will a larger pan help on heat as well or is my cooler large enough?
