PCM TCM 4l80e idiot question
Old Jan 6, 2010 | 01:57 PM
cjmatt's Avatar
Default PCM TCM 4l80e idiot question
Does the PCM control the 4l80e? I keep hearing how I'll need a TCM to control it, but I was under the thought process that the TCM was only necessary if I was using a carb setup.
Is the TCM an external or internal device if it is needed?
My mustang has the painless 4l60e harness but has always had either a t56 or th350 in it, but all the plugs are there. I just wanna put this thing in as cleanly as possible
Old Jan 6, 2010 | 03:39 PM
slow67's Avatar
Gingervitis Addict
Depends on the year of the PCM. Newer PCMs don't control the transmission, and it has a seperate TCM.
Old Jan 6, 2010 | 05:02 PM
cjmatt's Avatar
its a 99 ls1 pcm
Old Jan 6, 2010 | 06:12 PM
slow67's Avatar
Gingervitis Addict
its a 99 ls1 pcm
Then your PCM controls the trans.
Old Jan 6, 2010 | 07:28 PM
cjmatt's Avatar
ok whew, i know i gotta repin it and all, i was just hoping i didnt have to buy another module
Old Jan 7, 2010 | 12:34 PM
Aaron91RS's Avatar
you'll have to get a segment swap
