Stall
Old Jan 7, 2010 | 08:24 AM
Bo's 98 TA's Avatar
Default Stall
What all do I need to do to my trany before I put a 3600 stall in my 60E, any info will help.
Old Jan 7, 2010 | 09:44 AM
witry's Avatar
honestly it all depends on your tranny... if the tranny is in good working condition then all you need it some good fluid, a tranny cooler is a must and a tranny temp guage is also a must... that converter will build up some heat so you want to monitor the tranny... and since you will have the tranny out and you dont know the condition of it have it looked at to make sure its in good condition because after that converter is in that car should wake up
Old Jan 7, 2010 | 10:29 AM
Bo's 98 TA's Avatar
OK thanks, my tranny is in great working cond.
Old Jan 7, 2010 | 05:55 PM
Bill Bowling's Avatar
I changed the tune on mine. Increase the pressure and get rid of torque management. You also might need to disable a couple of codes.
Good luck.
Bill
Old Jan 7, 2010 | 08:58 PM
MYSTIC-1SC's Avatar
install a shift kit and change your fluids and filter and get a tune.
