Flexplate help
Old Jan 15, 2010 | 01:32 AM
blackhawk0251's Avatar
Default Flexplate help
Correct me if im wrong but I feel like an idiot for posing this because I am the Automod. Is this the correct TCI flexplate? Its stating LS1 to 4L80E but....
http://www.summitracing.com/parts/TCI-399754/
Old Jan 15, 2010 | 02:32 AM
JeaneZ28's Avatar
If you're looking for the one for a 4L60 here you go.
http://www.speedinc.com/catagory.cfm...y=Transmission
TCI399753
Old Jan 15, 2010 | 08:23 AM
Link is broken, but ill try the part number.
Old Jan 15, 2010 | 08:27 AM
Circle-D's Avatar
Depends on what you are doing. Are you converting to a 4L80? What are the power levels?
Chris
Old Jan 15, 2010 | 08:29 AM
I found the part number here
http://www.summitracing.com/parts/TC...n/?prefilter=1
Old Jan 15, 2010 | 08:30 AM
Chris
Ill probably only be pushing around 520ish crank. I think this is the one for the 4L60E - LS1
Old Jan 15, 2010 | 08:34 AM
JeaneZ28's Avatar
That is the one for 4L60 to LS1. The line I posted was to speed inc. They are $10 cheaper than summit with free shipping.
Old Jan 15, 2010 | 08:43 AM
Circle-D's Avatar
The one you found in the link is correct for the LS motor and 4L60 Trans, SFI 29.1 of course.
Chris
Old Jan 15, 2010 | 08:49 AM
Thanks LS Tech Brethen
Old Jan 15, 2010 | 10:12 AM
01ssreda4's Avatar
They are even cheaper direct from TCI. This is from their website:
TCI PART NUMBER #399753
BRAND NEW IN THE BOX TCI SFI APPROVED FLEXPLATE FOR GM LS-SERIES ENGINES 1998-UP.
TCI® Flexplate 1998-2002 Camaro/Firebird LS1, 1999-Up GM Trucks 4.8L/5.3L/6.0L
Flexplates are .035" thicker than stock and the starter ring is welded to both sides of the flexplate for additional strength. Constructed from a high tensile strength material these flexplates resist elongation and cracking. All 168 tooth flexplates are sized for stock 3/8" mounting bolts and can be easily drilled for 7/16" diameter high performance torque converter applications and are SFI 29.1 approved.
Old Feb 22, 2010 | 10:49 PM
bad6as's Avatar
i got a brand new one for sale.
