lets talk "blow thru"
Old Jan 16, 2010 | 12:17 AM
Tzion_ben_Arthur's Avatar
Default lets talk "blow thru"
Just to clear things up a little, I want to make sure I understand this right. I have heard the term too loose or too tight, or you make enough power to "blow thru this one". I think most of us are beyond the days of picking a B&M converter based advertised stall for our 350 79 camaro with a VS carb and powerball cam. We are in a time where TQ and HP numbers are far greater than our fathers would ever imagine in a street driven car or truck. We actually make enough power to twist up a TH400 or brake a 9" if not built correctly.
With this all in mind, i have lost sleep at night worring about my torque converters performance - heart disease or cancer even takes a back door to my new phobia. I now have a collection of converters from Vig 2800 to a yank pt4000 and if I listen to some folks, none of them will work for me. Here is what I need... I am going to give an example below. If I am correct good deal. If I am not please correct me.
Lets say I have a converter that flashes to 3800RPM with my 450rwtq 3300lb car. I shift at 7000RPM and I loose about 300 rpm between shifts. Lets say I shoot the same combo with a 200shot and torque jumps 160lb across the powerband. Now the RPM jumps to 5000 right off and when I shift at 7000 like normal I get a drop of about 150 rpm. Last my 300 shot takes me to 6800 and I never feel the shift and the shift light stays on the entire run.
Which is blow thru and shift extension?
Old Jan 16, 2010 | 01:14 AM
camscam02's Avatar
you want a rpm drop of about 1000 or so for best performance, this is about the standered for a nitrous car. less extension it is loose, more extension it is tight.
The only way you will get the right converter is have a dealer build one for you based on your wants, then give them data on it and they can prolly make it better the second time around.
Old Jan 16, 2010 | 07:48 AM
dnkynrbk's Avatar
I would have a nitrous stall built for your car. You cant buy a stall off the shelf and it work a 100%. With nitrous you my have to slowy bring in the nitrous if you car is blowing thru. This happen to me on my old set up
Old Jan 16, 2010 | 08:35 AM
Thanks guys. My turbo car takes one type of converter and my NA/Nos car takes another.
I have talked to Greg at FTI about a PG trans and converter combo, but I need to get some of this stuff out of my first.
