th400 and boost?
Old Feb 16, 2010 | 12:53 AM
TraviZ's Avatar
Default th400 and boost?
Do I need to worry about putting a specific modulator in a th400 that is behind a boosted engine? Perhaps one from the 80 formula would work since it had a factory turbo?
or does it matter?
Old Feb 16, 2010 | 07:14 AM
72blownvert's Avatar
Imo you should get a manual v/b but if you want the trans to shift automaticaly get an adjustable modulator.
Old Feb 16, 2010 | 08:40 AM
forcd ind's Avatar
TCI sells a valve that goes in your vac line to block boost, has to be mounted a certain way to work-i had one on a man shift 4L80E where they used the mod in place of the force motor
i have run them just the reg way ok, but always felt it shifted better under power as a man v/b
Old Feb 16, 2010 | 01:38 PM
TraviZ's Avatar
I already have the trans put together and installed so I dont wanna pull it for a manual vb swap. this is a cruiser as much as it is a quarter mile monster.
I will probably just run it the way it is and see how it reacts. if I start spewing tranny fluid out the seals I will know why lol.
Does anyone know by chance how the modulators on a TTA from 1980 was setup from the factory? maybe they had an inline piece I could get my hands on if required. if not ill go the TCI route forcd ind mentioned.
thanks
Old Feb 16, 2010 | 11:22 PM
jakeshoe's Avatar
There are a couple of things you need to do for the TH400 with boost.
You can run the automatic VB no problem, we've done so on TH400s in turbo applications to ~900 HP so far without issue (years on that trans).
The boost checkvalve already mentioned is a TransGo piece.
There is another important modification to do but I won't discuss it on an open forum. PM me for details.
Old Oct 4, 2020 | 01:23 PM
DCobb's Avatar
Jake,
this is old ^^, but i need help with this same issue. We've already used the checkvalve, need to know the other mod to get the auto/manual th400 to shift and last.
