glide costs
Old Feb 16, 2010 | 09:28 PM
daniel6718's Avatar
Default glide costs
besides the shifter/1000-2000 converter/new driveshaft/tune/crossmember
what are yall guys spending getting one built? i hear about these guys having stock glides like 600-1000 builds lasting but every builder wants to do a 3000 dollar build on one...
say around 800hp cars about 3100 raceweight...should go low nines...like 9.30ish hopefully faster
Old Feb 16, 2010 | 09:58 PM
72blownvert's Avatar
You can build a glide to handle 800hp for about 1,500.00 give or take. stock case,stock planets,dual ring servo,red lined band,roller governor support,deep pan,trans brake v/b with 225lbs of line pressure,8 clutches in high gear,5 in low reverse. Alto clutches & koline steels,4340 input shaft,hardened high gear clutch hub,modified pump w/hardened stator support.
Old Feb 17, 2010 | 06:42 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
we have units like the one mentioned above for 1159.00 and with 180 straight cut planet for 1699.00. these are in a stock case.
Greg
FTI
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
