More TH350 trans ???'s
Old Feb 28, 2010 | 05:08 PM
31camaro's Avatar
Default More TH350 trans ???'s
quick question guys if i swap a th350 into a 3rd gen camaro what all is needed? does the output shaft on the TH350 have the same spline count has the TH700r4? Also can I use the stock driveshaft? These questions are by a friend of mine so any help is appreciated, thanks guys
Old Feb 28, 2010 | 06:09 PM
31camaro's Avatar
Originally Posted by Bro Inc
It has the same spline as the 700R4 and the 4L60E. If you have the 9" long tail shaft the stock driveshaft should work, yoke and all.
thank you very much for the reply
