Tech question for the sponsers
Old Mar 10, 2010 | 12:27 PM
MattysTA's Avatar
Default Tech question for the sponsers
have any of you guys ever seen/had this happen? I rebuilt this trans myself last year. but the car has been off the road for 7 months due to losing the 3/4 gears and also my converter clutch burned up as a result. the pic is my forward clutch return spring cage. the reason for the aluminum pump is because i installed the sonnax steel sleeve. i found someone that offers a modified steel piston with this kit so ill be upgraded it so i can use the full spring cage again. i was just curious if any of you guys have seen this happen before...
