60ft times with stall
Old Mar 29, 2010 | 03:49 PM
supersean's Avatar
Default 60ft times with stall
what should a bolt on car with a yank ss3600 60 ft?? my car just doesnt leave as good as it should. with nitto dr's on a 15 in wheel at 18 psi. i only had a 1.97 60ft. car hasnt been tuned yet but damn! lol
Old Mar 29, 2010 | 05:20 PM
odarabla's Avatar
You need to get it tuned. My car was cutting low 1.6's on ET streets with a PTC 3600 stall converter and full boltons. How much are you stalling the car up when you launch?
Old Mar 29, 2010 | 06:56 PM
supersean's Avatar
I was only leaving around 2k maybe a tad bit higher but not much. car went 8.35 @ 86 which ppl are telling me isnt very good for a bolt on..stalled car either
Old Mar 29, 2010 | 07:09 PM
StealthFormula's Avatar
I would say in the 1.6's, 1.7's at the least. Were you spinning? Nitto's aren't exactly the best drag tire ever but still should be able to do decent with them. With the SS3600 I was leaving the hardest launching from just above idle.
Old Mar 29, 2010 | 07:10 PM
odarabla's Avatar
Like I said before. A tune will help out with your issues. Right now if you are full boltons you are running the car lean and possibly lossing hp because of it.
Old Mar 29, 2010 | 07:24 PM
Ls1Rook's Avatar
Saw your vid, looks like your just spinning off the line the mph is there, get a basic tune and work on your launch.. practice
Old Mar 29, 2010 | 07:32 PM
supersean's Avatar
yea i was spinning a lil, just need to mess around some more, that was the first trip to the track since the stall. hope to have it tuned real soon, would like to hit low 8's
Old Mar 29, 2010 | 10:36 PM
02 wife's Avatar
Also get a good burnout! Nittos need heat to work effectively!
Old Mar 29, 2010 | 10:45 PM
SlayerMaro's Avatar
Yeah, try getting a better burnout.
I was getting crappy burnouts when i would would back into the water box, then do my burnout where it was dry. I'd get wheel hop or a best 60 of 1.9.
I got much better ones when I backed into the water box, then did my burnout in the area where it's still a bit wet from the box. Put the car in 2nd gear, and get your burnout rpm to 5k or so...do that for 3-4 seconds, let off the brake, then the gas to finish.
Some people get better 60 foot times with a stall when they leave off idle, some do better when it's stalled up. I brought the RPM up to 1750 or so, and got a 60 foot of 1.64.
Old Mar 30, 2010 | 06:18 AM
supersean's Avatar
ok thanks for the tips guys. what psi where you all running in your tires? i tried 18 psi and it still spun a lil
Old Mar 30, 2010 | 07:49 AM
01ssreda4's Avatar
you should be able to cut 1.6x, low 1.7x all day with a hook.
Old Mar 30, 2010 | 07:59 AM
supersean's Avatar
Id love to hit 1.7s or low 1.8s. that would put me on track to a 7.9 pass i would think
Old Mar 30, 2010 | 08:29 AM
01ssreda4's Avatar
Seriously, my Edge 3200 would cut high 1.6xs and 1.70 flats all day. My Yank 4k hits even harder so I know it can produce the same or better.
Old Mar 30, 2010 | 03:02 PM
2000SS1979's Avatar
With no tune and my Yank PT3800 I would cut 1.65's nearly every launch leaving off idle.
So I just think you need to heat those tires more.
Old Mar 30, 2010 | 03:22 PM
lsjuanmike's Avatar
12-14 psi is ok with nittos and heat the crap out of them.
Old Mar 31, 2010 | 01:28 PM
SSmoken's Avatar
same here
Old Mar 31, 2010 | 02:29 PM
supersean's Avatar
damn i way behind everyone then...my cars has always been a lil sluggish
Old Mar 31, 2010 | 02:37 PM
tdevil55's Avatar
I cut a 1.97 on a stock stall with MT DRs, but I have a line lock and smoked the tires well before I staged. I would agree with others on the nittos, smoke the crap out of them and watch that 60 go down. Also try idle launch and higher RPM launch, see which one gets you the better 60.
Old Mar 31, 2010 | 03:21 PM
Goat2NV's Avatar
I went a 1.71 60ft w/ 2.73 gears and 275/40/17 Toyo drag radials.
Old Mar 31, 2010 | 04:01 PM
supersean's Avatar
yea hopefully ill get back to the track in a week or two and expiriment a little with launching and smoke the hell outta of those tires. any suggestions on tire pressure that works well with those tires? whats sad is ive had a 1.99 60ft on street tires and stock stall myself
