Shifter cable bracket question....
Old Mar 31, 2010 | 02:42 AM
salemetro's Avatar
Default Shifter cable bracket question....
I'm finally installing my swap, and have run into a problem with the shifter cable bracket on my 96 f-body. I got rid of the v6 gear, and am now installing the turbo'd ls-based powertrain....with a 4l80e (thanks FLT!). I used the selector-shaft bracket from the old 4l60e on the new trans, but the bracket that holds the cable housing to the trans does not line up with the bolts on the new 4l80e oil pan.
Where can I find the needed bracket?
Thanks for any help.
Old Mar 31, 2010 | 11:49 AM
Bad30th's Avatar
Some folks are able to slot one of the bolt holes in the bracket to get it to fit, and then adjust the cable. Just an idea...
Other than that, junkyard or GM parts counter if you need to find a 4L80E bracket...
Rob (Bad30th)
