6L80E in a 4th gen with an LQ9?
Old Apr 3, 2010 | 07:04 AM
Gripenfelter's Avatar
Default 6L80E in a 4th gen with an LQ9?
Did any of the trucks come with a 6L80E?
Can I run a truck PCM so I can run an LQ9 with a 6L80E?
What reluctor ring would I need?
Old Apr 3, 2010 | 10:39 AM
poorhousenext's Avatar
Yes. I'm using 6L80E and yoke out of 2WD 2008 GMC truck.
It's behind LS7 so I'm using PCM for it.
Looks like using LQ9 PCM will be a problem. I believe the LQ9 has a 24 reluctor ring. If it has 58 reluctor ring it'll work.
You may want to check out Mast MotorSports. They have a PCM that will communicate with 6L80 and 24 reluctor ring LS engine.
