Need help asap!
When you can see the bolts use 30" of extensions. I use one 24" and adjust the length with smaller ones at the end, and I use a 1/2" ratchet for leverage and a 1/2 to 3/8 adapter. I also use a universal joint with a few wraps of electrical tape so it holds at a good angle.
Make note of the one under the drivers side floor, you might want to beat some clearance into it when you get it out.
