Chattering with shifter in 3
Old Apr 4, 2010 | 01:29 PM
onebadapple98's Avatar
Default Chattering with shifter in 3
Just installed new 3200 converter, car runs and drives fine in D, but when you put it into 3, you get a chattering i believe from the converter, and the car vibrates. This does not happen at all in D. Car has a hand held tune only, the only changes are performance tune, and speed limiter. Transmission has Transgo HD Shift Kit, no washers. Any help with this would be appreciated, do I need to get a real tune? I was hoping not to, until I changed the gears from 273 to a 342. Car has lid, ported throttle body, ls6 intake, new style slp headers.
Old Apr 4, 2010 | 01:45 PM
I didn't try that, I will thou, one thing, in 3rd before with the old converter, it did not do this. Just a little FYI. Thanks for your input.
Old Apr 5, 2010 | 03:14 PM
Originally Posted by Bro Inc
It's locking up in third, stock lock up programming.
It's too low rpm vs speed.
What you hear and feel is drivetrain chatter, like driving a manual trans in 5th at 25 mph.
When you set your foot on the brake pedal it goes away right?
Well I tried the brake and your right on the money, I also notice it a few times in 4rth also. Guess its time for a tune . Do you think it would do it less with a higher gear like a 342 over the 273.Thanks
