Hughes + ARP bolt length issue
Old Apr 21, 2010 | 08:20 PM
96gt4.6's Avatar
Default Hughes + ARP bolt length issue
I'm in the process of installing an LQ4 build and am having an issue with the flexplate mounting.
I have a Hughes 4L60E flexplate and a set of the short ARP flexplate bolts. The bolts have a slight shoulder that is protruding past the flexplate. The crank doesn't appear to have a recess before the threads begin and I believe the bolts will bottom before the plate is tight, although I haven't tried yet.
Ideas?
I thought about spacing the bolts out with a lockwasher, but am unsure.
Old Apr 21, 2010 | 08:49 PM
96gt4.6's Avatar
Upon further searching, it would appear that I need ARP#244-2901, unless someone has a clever idea on these.
Old Apr 21, 2010 | 09:07 PM
96gt4.6's Avatar
Old Apr 24, 2010 | 01:18 PM
96gt4.6's Avatar
Originally Posted by Bro Inc
yea, those are flywheel bolts.
the flexplate bolts 244-2901 are what you need.
Worked like a champ!
You wouldn't happen to need a set of 330-2802's would ya?
