Factory tranny cooler lines question
Old Jan 7, 2004 | 05:19 PM
Kumar 98Z's Avatar
Default Factory tranny cooler lines question
Quick question, does the tranny cooler line at the bottom of the radiator go to the bottom fitting on the tranny or vice versa?? Thanks in advance.
Old Jan 8, 2004 | 11:30 AM
BYOFICR's Avatar
What exactly are you trying to do?
Old Jan 8, 2004 | 04:17 PM
Kumar 98Z's Avatar
i took both the factory lines down to flush them out and had a brain fart when i went to put them back in. Figured it out now, it's all back together, top to top, bottom to bottom. Thanks!
Old Jan 9, 2004 | 03:23 AM
BlackWS602's Avatar
the line that goes into the bottom of the radiator is the return line.
Old Jan 9, 2004 | 03:24 AM
BlackWS602's Avatar
also the way the lines are bent its kinda noticeable where they go
