yeah after 60K of beating on the FLT Level 3 and Vig 3600 driving daily in all weather I have a problem... a massive trans leak! It started a couple weeks ago just a drop or two and I could not find what was leaking. Everything under the car looked wet and looked suspect. Now its leaking a lot worse which made it easy to find the problem.. it appears to be the seal on the input shaft.
Sucks!!! I was hoping it would be something simpler but this is my only car and can't afford the time to pull the trans myself in the garage and chance doing it myself and screwing it up. So I just sent the email to Speed Inc where I had the trans and stall done a couple years ago to have them do the work with FLT. hopefully it won't be too costly! At least I feel I got my money worth but man.. this sucks! Just as I was looking at brake Upgrades, new LCA's and 17" wheels and tires. I guess it will be just standard brake rebuild, New Rod ends for the rusty LCA's and just tires on the stock 16" rims.
