TH350 converter/flexplate question????
Old Apr 25, 2010 | 08:35 PM
o1m6ss's Avatar
Default TH350 converter/flexplate question????
What type of converter should I run for a turbo 350 on an 01 camaro? I know th stall size I want, just checking best type and I want to buy the correct one the first time. Please post links or reference part #'s if you can. I also need a flexplate. If you know the one I need please let me know. I looked through summit and I don't see a direct reference to what I need. I know I can get one with the wrong bolt pattern and I'm trying to avoid that also. Thanks for the help!!!!!
Old Apr 25, 2010 | 08:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
More info on your setup will help
Old Apr 26, 2010 | 08:13 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
01m6ss,
assuming you still have the ls series engine then we have the flexplate that you need in stock and we build the converters as well. You would either need a pilot extension or a longer pilot on the converter you are having built. If you use our flexplate the mounting bolt holes are not a problem but if you use lets say a TCI then you need to make sure you use a small bolt circle converter to mate up with the plate.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 27, 2010 | 12:06 PM
o1m6ss's Avatar
Default set-up info
I am running a 408 TSP motor with about 500hp to the rear wheels. My rear end gears are 3:42. My transmission builder said I need about a 3500 stall??? I plan on putting 4:10 gears so I'd like to plan for the future without burning up my trans in the process. Let me know your thoughts guys.
Greg, PM me a quote for the converter you think is best for my aplication.
