4l60e Transmission mount question
Old Apr 30, 2010 | 06:15 PM
StangEaterSS's Avatar
Default 4l60e Transmission mount question
I had a prothane poly mount in an ls1 car with a t-56 6-speed. it used only the center threaded hole with 1 stud with a nut to fasten it to the crossmember. the stud snapped clean off flush with the mount. this mount has 2 other threaded holes. I assume a 4l60e trans uses the other holes? can I use this mount on an automatic ls1 still? didnt want to throw it away if i could give it to a buddy.
Old Apr 30, 2010 | 10:35 PM
leonpiper69's Avatar
i would drill it and use an easy out.
Old Apr 30, 2010 | 11:49 PM
sjsingle1's Avatar
x2...........
Old May 1, 2010 | 09:09 AM
I tried and the damn thing snapped off. them easyouts are useless.
