transbrake malfunctioning
Old May 4, 2010 | 08:00 PM
lmt0705's Avatar
Default transbrake malfunctioning
im running a 4l80 with a brake and I took the new setup to the track for the first time. First pass it worked flawlessly, every pass after that it was releasing on its own when I got close to full flash on the converter. Any ideas?
Old May 5, 2010 | 06:15 AM
FLT's Avatar
FLT
How long were you on the brake when it worked and also when it was releasing? The reason I ask is I have seen pumps get damaged from being on the brake to long. Also in a turbo or SC application I like to see a good billet flexplate to avoid pump damage. Have you talked to Carl yet? Vince
Old May 5, 2010 | 11:31 AM
lmt0705's Avatar
It releases and relocks again, its not pushing thru it. Carl thinks it might be a wiring issue. Ill check it out today. I'm only on it about 3 seconds. Running an sfi approved flexplate. Think its tci, car is supercharged
