is it worth spraying my st-4000?
Old Jan 10, 2004 | 11:32 PM
gator's 99TA's Avatar
Default is it worth spraying my st-4000?
just wondering about this. i plan on spraying a 100 wet shot this coming spring or maybe even a dual dry 75 shot on my car. mods in sig. std car really. i know my tire and gearing are right for it. as it sits, i have a lot left in it mph wise before i shift into overdrive. will spraying this much make my flash point too high? maybe i should only spray after 1st gear? my car has run 11.59 @ 116 (1.51) so far shifting at 6600-6700 rpms. i reall like this convertor and dont want to swap if i dont have too. but is it a bad idea to keep it?
Old Jan 11, 2004 | 07:43 PM
up please
Old Jan 11, 2004 | 08:56 PM
B18B1LS1's Avatar
I sprayed the heck out of my TP4400 when my car was stock internal and it ran great. I'm sure I was leaving a little on the table with such a loose verter but I gained 1.2 seconds and 13 mph on a 150 shot. I say go for it and see what happens. Good luck!
Jeffrey
