How to determine stall of torque converter?
Old May 20, 2010 | 11:17 PM
OLDSCHOOL85's Avatar
Default How to determine stall of torque converter?
Bought a used 2000 Camaro. Was told the car has a stall converter(PINK IN COLOR) but the previous owner did not what size.
Flashes to about 4000rpm WOT.
My guess is the converter is a vig 3600? Any guesses? Any way to determine stall speed without a transbrake?
Old May 21, 2010 | 01:09 AM
01SuperSport's Avatar
I don't really know but your guess sounds good
Old May 21, 2010 | 12:29 PM
Circle-D's Avatar
The best way is with a trans-break, flip the switch and floor it. But since you don't have a trans-break you can use the flash RPM. If it is flashing to 4000, then it is a 4000 stall in your setup. Converters stall will change based on input power. Hope this helps.
Chris
Old May 21, 2010 | 12:43 PM
01ssreda4's Avatar
Since Vigs tend to be a little loose as most say, it very possibly could be a 3600.
Old May 21, 2010 | 01:25 PM
Default Stall Question
Any other inputs?
Thanks for the replys
