Guesses on Converter Size?
Flashes to about 4000rpm WOT.
My guess is the converter is a vig 3600? Any way to determine stall speed without a transbrake?
Please add your guesses based on prior experience with a stall?
Is your engine pretty stock? The stall speed is rated on whatever the stock power level is for the particular car that it fits, so if you are making more power than stock you'll see a higher stall speed.
