4l60e does nothing
Old May 31, 2010 | 12:19 AM
1slowsierra's Avatar
Exclamation 4l60e does nothing
I have a 2001 gmc with a 4l60e I built the tranny a few months ago and now have around 2500 miles on it now was driving today and it just quit pulling I stopped pulled it down in 1st 2nd 3rd and od nothing then put it in reverse nothing the indecater does not work. Any ideas would be apriciated.
Old Jun 7, 2010 | 07:48 PM
does nobody know anything about the 4l60e on this forum!
Old Jun 9, 2010 | 07:52 PM
Fluid pressure is fine used the same converter that came out fluid levels are fine when I pull it down into drive the indecater does not move from park and the traction control light comes on.
Old Jun 9, 2010 | 09:12 PM
Silvy6.0's Avatar
I don't understand how someone can build something and then have soo many questions about why somethings not working. Sounds like you have an electrical issue. Did you replace any of the solenoids? If you "rebuilt" it the right way, you would have replaced everything.
Old Jun 11, 2010 | 06:59 AM
FLT's Avatar
FLT
With no movement I would suspect a broken pump. Bro was asking if you checked pressure and that is where I would start.
Old Jun 11, 2010 | 05:59 PM
Replaced everything includding solenoids. This is the first 4l60 that I have ever delt with just looking for some ideas that others may have come acrossed with this transmision. If the pump had broke would there not be metal in the fluid?
Old Jun 11, 2010 | 08:05 PM
Pressure at idle is around 72. I flushed the converter and the cooler was brand new. I ordered a new converter today.
Old Jun 11, 2010 | 08:10 PM
The tranny did not fail I decided to rebuild when the new motor went in. I figured it was due after 3 years of increased line pressur and being abused dailly
 Michael S. Palmer
Old Jun 11, 2010 | 09:00 PM
Drivn2Fast's Avatar
IIRC when you move the gear selector, you are still physically moving the valve in the valve body, but the way the computer knows which gear you are in is that there is a sensor on the valve body that shows which part of the circuit has pressure. You could try replacing that (part 69 in the attached picture).
Old Jun 11, 2010 | 09:41 PM
Predator T/A's Avatar
ok so you have 72 psi at idle which is within spec, but you have no movement either the convereter is bad or the input shaft is broken or the input drum is broken however something is most likley broken and looks like you will geta chance to find out. what was the endplay on the unit when you put it back together?
Old Jun 11, 2010 | 11:05 PM
Originally Posted by Bro Inc
Unplug the wire harness and see if it'll move.
This will de-energize the shift solenoids so it'll be stuck in third, and the epc will be at max line pressure.
Put it in a forward gear, if it doesn't move take the transmission back out and do it over.
You either take it out and find the problem, or you get a hundred tips off the internet that leads you to chasing your tail and getting nowhere.
if he has nothing in all ranges lolthen thats pretty much and indicator that something came apart lol I remember my firsttranny also lol
Old Jun 11, 2010 | 11:17 PM
firehawk618's Avatar
First thing that popped into my mind too from the "it does nothing" symptom.
I just don't know a single guy who can build his own transmission but then not know how to diagnose it.
Old Jun 11, 2010 | 11:51 PM
hey guys take it easy on him lol he is learning we all had to at one time at least he tried.
Old Jun 12, 2010 | 01:05 AM
I sure appreciate the critacism guys was looking for some advise but aparently this forum is not the place to get it. I checked evryrhing I knew to check and still getting the smart *** remarks that it awesome been a real help.
Old Jun 12, 2010 | 01:35 AM
lt1pwr1's Avatar
I agree, I think a couple of you guys need to release some of that hot air out of your heads. Everyone was a beginner at one point and I think some guys forget that.
Old Jun 12, 2010 | 01:08 PM
Drivn2Fast's Avatar
First off, I commend you for undertaking the rebuild yourself. My response was based on the fact that you said the indicator does not change from park when selecting the gear. That and the fact that you traction light comes on still leads me to believe it is electrical. I'd be checking continuity from the connector to the part I pointed out in my first post. Also check the speed sensor.
