track results
Old Jun 5, 2010 | 12:13 AM
1lt1wiz's Avatar
Default track results
hello went to track to night and not happy i ran a best of 14.5 with a 2 somthing rt the car has moroso cold air performabuilt level 2 trans with his 23 2500 stall and a tsp rumbler free mods the problem i have is when i launch it at 2500 it feels like its hitting rev and u have to let up a bit any help would be helpful
Old Jun 5, 2010 | 12:55 AM
608kZ28's Avatar
posting more of your time slip will give us more info.
you using street tires or drag tires?
Old Jun 5, 2010 | 10:06 AM
1lt1wiz's Avatar
Exclamation hey
ok street tires rt.. was .167
60.. was 2.154
8th.. was 9.358
mph for 8th was 75
1/4 14.542 mph 94
Old Jun 5, 2010 | 11:29 AM
FLT's Avatar
FLT
If you are hitting the rev limiter then I would be looking at a couple things. First would be transmission data when you hit the rev limiter. If the trans has not be commanded to shift well it's not the transmission fault. It's more of a tunning issue if a slip is not detected. I would look at these things first and go from there. Probably should get in contact with your tuner and your builder to see if there is something they can do for you here. Vince
