P0751 code after FLP install can I delete it?
Old Jan 19, 2004 | 07:25 PM
The Guy in MY 99TA's Avatar
Default P0751 code after FLP install can I delete it?
I have actually had this code for a while and I forgot about it b/c my SES light stays on b/c of my o2's. BUT It says something about the 1rst gear shift solenoid. BUT if I'm correct the Level 4 doesn't have one does it? I was thinking that first gear was completely vacuum modulated. I also started noticing that if I put the transmission in first and cruise up to like 10 mph and let off it seems to want to down shift to a lower gear but it jumps right back into gear. Anyone else noticed this? I just noticed this this week.
Josh S.
Old Jan 19, 2004 | 09:09 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The vacuum modulator replaces the electric pressure control solenoid, and they use some sort of sim to keep the code away for that. The gear shifts are still computer controlled, only the line pressure is moved to vacuum control....
Old Jan 20, 2004 | 07:52 AM
Ragtop 99's Avatar
I've seen that code show up in cars with loose converters. Almost every time it has been because of the converter and not a real problem.
Old Jan 20, 2004 | 11:57 AM
StreetStalkerZ's Avatar
I have had that code haunting me for a year now and i thought about getting it deleted but as for now i just ignore it and clear it with the autotap but it keeps coming back after about 500 miles of driving. It's converter related from what i can tell of it and nothing transmission internal wise.
Old Jan 20, 2004 | 01:46 PM
Ok thenz! Thanks guys!
You know of anything with the first gear problem?
Josh S.
