Did i choose the right converter for my setup?
Old Jan 21, 2004 | 04:07 PM
98pontam's Avatar
Default Did i choose the right converter for my setup?
after doing some reading on the boards i went ahead and ordered a TCI 3500 2.5str..
my mods are
SLP Lid
Pacesetter LTs
3" offroad-Y
3" hooker catback
3.42s
BFG DRs
this is about as far as i am going to mod the car for a while..
so i am hoping i made the right choice in stall speed and str
your thoughts?
Old Jan 21, 2004 | 04:34 PM
Pete2k_Z28's Avatar
Yeah, that sounds about right. I don't know how the TCI's stall compared to the Yanks, but 3200-3800 seems to be a pretty good range for a mostly stock car.
Old Jan 22, 2004 | 11:57 AM
Ed Blown Vert's Avatar
The Stall speed is good. But that STR is going to be hard on the DR's
Old Jan 22, 2004 | 12:04 PM
samz28's Avatar
just remember to not leave the ASR off lol.
I annihiliated my 16" 555R DR's on a WOT @ 25mph. Kicked out sideways, very scarey.
the converter is loose from 2000-3000rpm (depending on inertia necessary). So its not very street friendly compared to stock. But it sure does kick some *** for the $$ I think its a good choice.
see my list of mods.
Old Jan 22, 2004 | 07:46 PM
MontereyLS1's Avatar
i love mine, i think its more streetable now, but thats just me i guess......launching is gonna take ALOT of practice. even with DR's you'll be able to blow the tires off at will anytime below probably 40mph. from a stop, floor it and you'll be most of the way thru 2nd gear b4 the car starts getting any kind of traction. makes an a4 so much more fun!
Old Jan 22, 2004 | 08:28 PM
98pontam's Avatar
thanks for the input...
one other question... do i need a shift kit to keep the shifts firm? i have them set to 75% on the HPP3 but will that be enough with the stall or should i look in to getting a real shift kit?
Old Jan 22, 2004 | 10:20 PM
Jpr5690's Avatar
Smile
what about for me is that a good converter i plan on doing a shift kit and long tubes too and as of now my garage is stocked with suspension parts (lcas tq arm lca relocs stb sfcs panhard sway bars tunnel brace and rear end brace) all about 2 be installed so far ive run a 12.6 with wheel spin im hoping the suspension will plant the wheels and give me the traction i need for a good 60' but what i want out of an converter is to get kicked in the back on launch and still be tight when im up in the 130 mph range...
Old Jan 22, 2004 | 10:22 PM
Jpr5690's Avatar
cars a semi daily driver but no real city use just open roads and draggin on the street
Old Jan 22, 2004 | 10:30 PM
If you are spinning now, a converter will make it worse.
If you want a good launch and from a roll. You going to need a STR of 2.0 or lower and a higher stall.
Old Jan 23, 2004 | 12:37 AM
DeepBlueZ's Avatar
my old converter and my Vig were both 2.5 STRs. i can DEAD hook on 17 inch drag radials with a 2000 RPM launch on an unprepped street with 18 PSI and a burnout.
Old Jan 24, 2004 | 03:44 PM
Jpr5690's Avatar
well i want something thats gonna be great from a stand still and a roll with good efficency ... basicaly i wanna swallow my toung off the line and liike i said i just bought like the cars whole suspension so im sure ill hook a good eal better with it.
Old Jan 24, 2004 | 04:12 PM
MARKSZ71's Avatar
i like my 3500 tci i kinda wish i had a smaller 3200 for the street but dam it will blow the tires off at will.
