4l60E trouble
Old Aug 3, 2010 | 07:21 PM
superman2002's Avatar
Question 4l60E trouble
I bought MY 2002 Z-28 had 32000 at 36000 the tranny went out no third. Rebuilt with stock convertor, aftermarkket cooler, beast sun shell, hd clutches super servo, high rev & trans go hd2 shift kit. lasted 3999miles and third is gone again putting in z pac and street fighter stall anything else i need to look at? Any info woul b greatly apprciated.
Old Aug 4, 2010 | 01:17 AM
performabuilt's Avatar
LS1Tech Sponsor
A failure at that milage no matter what clutch set you use is likley hydraulic issue ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 4, 2010 | 06:48 AM
itlwin's Avatar
Default 4l60e
i have the same problem with mine. is there any more hd parts that you can throw in it?
Old Aug 4, 2010 | 09:45 AM
LS1Tech Sponsor
There is more to it than just parts , its about the hydraulics and making those parts work together. You can put together a trans with the best of the best of everything and still not have anything that will do any better and maybe worse than stock . You can massage the hydraulics in a stock build and far exceed the stock trans capabilities.
__________________
Call 888-744-6542
