could 1le mount change pinion angle...?
Old Jan 21, 2004 | 11:09 PM
mikemodano9c's Avatar
Default could 1le mount change pinion angle...?
when my stock tranny mount crapped out a long time ago i put a poly on and didnt like it...so i got a 1le mount. my question is...could a 1le mount change the pinion angle? i don't have a stock mount around and was wondering if the 1le is larger than the stocker?
i couldn't imagine putting a stock back on...it looked pathetic...
any opinions?
Old Jan 22, 2004 | 12:23 AM
Cheatin' Chad's Avatar
The 1le mount is the same mount used as stock on the 01-02 (maybe other years as well).
You shouldn't have any problems with it.
Old Jan 22, 2004 | 01:02 PM
my stock mount and the 1le mount were different...i have an 02
Old Jan 22, 2004 | 01:13 PM
2xLS1's Avatar
The 1LE mount is about 1/4 inch taller, so yes, it will change the pinion angle slightly.
