Vig. Converter
Old Aug 22, 2010 | 01:20 AM
1nasty86's Avatar
Turd Gen Guy
Default Vig. Converter
i have a vigalante 3600 nitrous converter in my car. with 3.55's it will only foot brake to around 2000-2200. my friends circle d 3200 stalls more than mine so whats up? could i have it sent off and loosened? i also have not sprayed the car yet so i have no clue how it reacts when sprayed.
Old Aug 22, 2010 | 01:36 AM
02sleeperz28's Avatar
I have a 3600 vig in my car. I don't think vigs like to be flashed that high. I play with mine anything from idle to 1300 rpm maxed.
Old Aug 22, 2010 | 01:38 AM
1nasty86's Avatar
Turd Gen Guy
guess not.. i could take my foot off the brake at a stop light and my car at the time was a cammed 5.3 would start moving easily..
Old Aug 23, 2010 | 02:33 AM
PBA's Avatar
PBA
It is almost impossible to foot brake a vehicle to the stall of the torque converter. The resr end gear ratio 1st gear of this transmission and the brakes have a lot to do with it. If you could put it in 2nd or 3rd gear, then you might be able to foot brake it to the stall. Disconnect the plug at the transmission and that will give you a 2nd or 3rd gear start, then you might be able to foot brake it. Most torque converters are flash rated, which would be close to the foot brake rating (if you could get it) if it were not for the numerical torque multiplication of the rear end gear ratio and the 1st gear ratio in the transmission.
Old Aug 23, 2010 | 04:25 PM
1nasty86's Avatar
Turd Gen Guy
i understand... i just thought i could get more foot break out of a 3600 converter.
Old Aug 24, 2010 | 12:36 PM
1nasty86's Avatar
Turd Gen Guy
nobody has any ideas? im debating buying a 4000 vig. or could i just get mine loosened and be able to foot brake higher?
Old Aug 24, 2010 | 07:56 PM
SAPS's Avatar
send it to Vig and have it re-stalled...tell them your setup and they will make sure it stalls at the speed you want.
Old Aug 24, 2010 | 08:01 PM
jsteele90's Avatar
i flash mine from the tree. no need to foot brake it that high. i leave around 1500 rpm
Old Aug 24, 2010 | 09:17 PM
slayer performance's Avatar
^ what he said
plus niitrous converters need to be tight so you dont flash through the converter when the nitrous hits.
