Converters And STR
Old Aug 27, 2010 | 09:42 AM
Tyler_PinkertonZ28's Avatar
Default Converters And STR
I have yet another converter question:
When it comes to STR is it better to have a higher or lower number? I know that the higher the STR the higher the amount of torque is, but is that necessarily the best for a street car? The reason I ask is I am stuck between two converters both of which are 3600 stalls but one has a STR of 1.86 while the other has a STR of 2.5.
Old Aug 27, 2010 | 06:45 PM
skat's Avatar
I have a 2.16 STR. Mods and power in sig. I love mine but wish I had went a little mote aggressive.
Old Aug 27, 2010 | 06:56 PM
How does it feel on the road? Does it take a lot of gas to get moving?
Old Aug 27, 2010 | 07:02 PM
Jays_SSZ28's Avatar
A high STR is going to require more RPM to get the car moving while driving the car normally. A low STR is going to move the car with less RPM.
Old Aug 27, 2010 | 07:08 PM
ok, so the lower is better as far as getting the car to move, but the higher is better as far as the amount of torque on the ground. Do I have that right?
Old Aug 27, 2010 | 07:26 PM
Jays_SSZ28's Avatar
Yes, with a high STR it'll blow the tires off easier but it might get old street driving at a higher rpm at a low mph.
There might be more to it. My converter builder told me about pump (impellar) fin exit angle and stator blade count and fin angle.
The way I understand it the stator has the most effect on STR and converter feel as far as tight or loose, and pump fin exit angle will fine tune that feel. I may be wrong on this but I watched him restall my converter with a different stator and pump with a positive fin angle and it went from too loose to just right.
If you're into cutting open junk converters you can use this chart to get a better idea of whats what. http://www.sonnax.info/announcements/STALLCHART.pdf
Old Aug 27, 2010 | 07:28 PM
Ok, i figured it was more complicated than i thought. haha. What kind of stall do you run?
Old Aug 27, 2010 | 07:35 PM
Jays_SSZ28's Avatar
The front half of a xxxx and the rear half of an xxxx yup... 3500 with a 2.1 STR, IIRC.
Old Aug 27, 2010 | 07:37 PM
haha. gotcha. I still don't know which converter I want to go with. I'll probably just do the higher STR, just to be more fun.
