need driveshaft advice
Old Sep 11, 2010 | 10:52 PM
Michael k Wood's Avatar
Default need driveshaft advice
i have a 94 v6 Camaro auto, well I'm in the middle of a 350 and th350 swap( I'll post a new thread with all the pics once I've finished the project) so i need to know if my stock DS will work. is it long enough and is the spline quantity right?
i'd appreciate any help.
i will probably be using motor plates
Attached Thumbnails need driveshaft advice-58543_147028445337038_100000896507700_232877_1767307_n.jpg
Old Sep 12, 2010 | 11:22 AM
Detroit Gearbox's Avatar
A th350 with a 9" tail shaft is the same length as your original 4l60e.
Some v-6 applications used a 2 piece driveshaft with a midship bearing . If so, you will want to switch to 1 solid shaft. You will also need a aftermarket cross member to attach your torque tube.
Old Sep 12, 2010 | 02:00 PM
thank you, it does have a two piece shaft. do you know anything about spline quantity?
Old Sep 12, 2010 | 06:30 PM
The spline on both outputshafts are identical, however some slip yokes are vented.
Old Sep 12, 2010 | 08:10 PM
thank you
