trans questions
Old Sep 19, 2010 | 04:19 AM
1funz28's Avatar
Question trans questions
have a 98 a4, putting in a vig 3200 what size cooler with slp ram air will fit? should i upgrade servo's? which ones if so? shift kit? which one as well if needed? anything else need to be done while the trans is out? also adding hooker l/t's, ory, i/m, and getting zex kit. how much will this drop the current et of 13.2 in the 1/4 on d/r's?
thanks in advance, any help is greatly appreciated!!! trying to bust by fox body friends a$$ again in the 1/4 mile begining of the season i was faster till he put a lot into his car now he is about .75 faster i am looking to make it to where he has a lot of more work to do to come close!
Old Sep 19, 2010 | 03:41 PM
1funz28's Avatar
any input?
Old Sep 19, 2010 | 06:20 PM
los p's Avatar
i dont know what ur times will be but it will for sure be a day and night difference with the new tc and zex kit!! but i would think your times should be at least a low 12 or high 11 if traction is not an issue and depending on how much u spray. im sure some people with that same setup can give u a better idea and good luck on knocking that mustang off!!
Old Sep 22, 2010 | 03:27 AM
1funz28's Avatar
anyone else?
