Got a good one for you
Old Sep 24, 2010 | 12:07 PM
Vertigo's Avatar
Default Got a good one for you
Just rebuilt my 4t65e-hd and it shift 1-2 fine 2-3 fine 3-4 fine but once in 4th or O/D it acts like i slammed on the breaks! The front nose dives towards the ground like i just dropped an anchor.
Im not getting any hard parts grinding or anything violent sounding besides increased rpms from the motor. It acts as if O/D is like putting it in 1st or reverse while at speed.
A friend told me that the seals are probably letting fluid by them causing the transmission to go into reverse. Ideas?
Old Sep 24, 2010 | 06:12 PM
FLT's Avatar
FLT
4T65E or 4L65E? In either case I would suspect a sprag or one way clutch in backwards. When a bind is found in a transmission this is usually the case. Vince
Old Sep 26, 2010 | 11:06 AM
performabuilt's Avatar
LS1Tech Sponsor
I would agree if its like the brake is applied in 4th the sprag is seized or there a cross leak keeping the overun clutch applied , The sprag has t free wheel in 4th and the overun clutch has to be off. In either case it sounds like and internal built issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
