no 1-2 shift with 4l80e when manual shifting?
ok i am still working out some bugs with my setup. one of them is the car not 1-2 with the shifter. i have a pro stick that i am using i have checked the operation of the shifter and it shifts selects all gears like it should. when the shifter is put in 3rd position the trans 1-2-3 like it should. if i put the shifter in 2nd position it shifts 1-2 like it should. now if i put the shifter in 1st position and try to shift to second it doesn't shift till i go to third position and it ***** to 2nd then third.
any one have or had this problem?
