Using 700R4 behind 5.3
Old Oct 3, 2010 | 05:34 PM
SSZ's Avatar
SSZ
Default Using 700R4 behind 5.3
I have the GM spacer and bolts and the flywheel is stock. DO i need to get a different flywheel at all? Mines not flat and i thought i read that somewhere. Also will the 700 converter work with this spacer or do i need a converter with a different pilot?
Old Oct 3, 2010 | 05:37 PM
jay_lt4's Avatar
when using the gm spacer with a flat flex plate the spacer goes on the crank first then the flex plate
when using a curved flex plate , the flex plate goes on first then the gm spacer
standard V8 700r4 converters will work fine with this spacer
Old Oct 3, 2010 | 05:49 PM
SSZ's Avatar
SSZ
Much appreciated Jay. Back to work for me.
